noelex
One question- I know that you need to run the watermaker every 3-4 days to keep it happy. But how long a run will it need? We don't have a big battery bank and only really have one day of reserve power. So we would want to make hay while the sun shines, and top up the tanks only when we had plenty of excess power. If we only need to do a ten minute run to keep the watermaker happy, then that's fine, but if it needs a proper blast that could turn out to be a bit of a problem.
Water makers like to be used. The ideal is a 2hr run every day or second day, but you can depart significantly from this ideal without doing much harm.
The longest the watermaker can be left without pickling is 5-7 days between runs. However, you can do a brief fresh water flush instead of normal run. This only takes 3-5 minutes so does not use much power, but does consume some water rather than producing any. If pickled, the watermaker can be left for up to a couple of years, but there is likely to be some maintenance needed if left for such a long time.
If you follow these running practices, good quality water makers are reliable and trouble free in my experience (perhaps we have been lucky). Our second water maker on our last boat made almost 50,000L of water and was still going strong when we sold the boat. The only maintenance apart from filter changes was the replacement of one low pressure feed pump.
