prv
that arrangement of the triangulated stays is to allow the mast to be lowered
That's true of the masthead shrouds at the gunwale, but people were talking about the forward lowers on the cabin top.
UncleAlbert,
you missed telling how well it works ?!
Very well, but the wheels do need replacing every couple of years as they get a bit of a beating from time to time as well as being uv sensitive ( I guess that built in replacement by plasticomo or whoever does 'em.
I am a great user of Softy Shackles.
One way to get over this problem of the genoa sheets cathing on the babystay is to have a sheet twice as long as normal and tie it to the clew with a bowline in the centre of this double length sheet. It works very well and rarely snags. Make sure you add 3 disposeable short lengths of say 10mm 3 strand rope in the bights of the knot so it can be easily undone at layup time. Used on a Moody 33.[/QUOTE]Since sailing Tam Lin this year I have found when tacking, especially in light winds, the Genoa sheets catch on the
Babystay. At the moment they are fastened to the sail with a shackle, which also catches. Will be thinking of ways to correct this over the winter.
Babystay.
Not wanting to correct Seajet but this is something I put on and not the rigger.
I read something on the WOA forum regarding using some plumbing tubing to help with the problem i was having. I went to Wickes and got some plastic 15mm white pushfit pipe and installed it. It has for the most part as helped stop the bowlines on the foresail from catching on the babystay. The idea is that when the bowlines get caught the tube rolls and releases the bowlines on their way.
Yes I know; remember, I have been to a couple of chandlers with you. :friendly_wink:I was rather hoping you'd go for the self tacker and big sail on a roller, not least as well as it seeming a very handy rig, it's always nice watching experiments like this when someone else is paying !![]()
Thoughts are now along the line of doing away with the Bowlines connecting the two sheets to the Clew and have one continuous line running through the clew from one side to the other. Question now is what type of knot will suffice?
I like the idea of very long line with bowlines halfway down but I fear that this may cause a bit of a mess in the cockpit area, or is this thought nonsense?
I may have miss understood the post, but I thought the suggestion was to take one full length of sheet and make a bowline the middle of it, incorporating the sail Clew into the knot?
Philip
Or instead of the bowline, insert and seriously whip a thimble into the mid point of the long sheet and use a softy shackle to attach to the clew. Even less bulk to pass the baby stay.
Or instead of the bowline, insert a seriously whip a thimble into the mid point of the long sheet and use a softy shackle to attach to the clew. Even less bulk to pass the baby stay.
