flykeith
Active Member
First off a little where is it?
Answer about as far from the sea as you can get in UK!
I brought Cayenne home last year to do some major work. Unfortunately the word major does not do justice to the work required. Whilst removing decades of paint from her counter, I found some soft planking and investigating further discovered the 'counter timber' is completely shot ( I am calling the central timber that runs from the stern post to the transom the 'Counter timber'. From the outside it seems sound, holds the fastenings well and sounds good to tap. But inside once the paint was penetrated I could scoop up the Oak?? with my hands.
So my plan is to remove all the plank end fastenings and the floor bolts, try and slide the old timber out and the replacement back in. Problem is the counter timber is of course, about 30mm wider at the forward end. I have removed an area of deck to gain better access.
Any of you wise guys done this before or have a better plan? Also I am lifting part of the deck, 1inch Teak, will structural integrity be severely compromised if I cut these so as not to have to go too far forward?
It's good to be back on YBW, could be nicer circumstances though.
Keith
Keith
