Concerto
Surprised that S3i have not been mentioned. Good kit at reasonable prices.
+1
Used S3i for my guard wire,s including side gates, last year. 9.7m long and cost about £400.
Will a swaged on stud fit through a stantions? Doesn't look like it. My guardrails have just a loop swaged on one end for the lashings to go through
Some really useful info here. In practical terms what is the difference between 4mm and 5mm guardwire? I can't imagine breaking 4mm wire, so why use 5mm?
The five years have been in high UV conditions. I use a carter's knot to tension them.
Unfortunately it is not just the UV. The 'Achlle's Heel' of Dyneema lifelines is abrasion, especially where it passes through the stanchions. This is aggravated through heavy use, e.g., during racing. This is why ISAF had second thoughts about it. Boats that do not get much use do not have that problem.
The halyard of my main is a form of Dyneema (8mm Liros Regatta 2000) but the lifelines remain stainless (uncovered, of course) .
Must be couple of years since I replaced mine to D12, wouldn't hesitate again knowing the stuff, nice r on the hands, just nicer all round.![]()
Yep - which is why I adore trying to break things in addition to reading forumsI won't argue with anyone's solution. At the end of the day we all take decisions with which we are comfortable.![]()
If I used Dyneema I would put it in a sleeve.The 'Achlle's Heel' of Dyneema lifelines is abrasion, especially where it passes through the stanchions.
We use these for large electrical cables to properly affix the lugs and they have dies from 4 to 70mm2 rated at 8 tonnes. At less than £20 they should go in hold baggage OK.
http://www.ebay.co.uk/itm/New-8T-Hy...e98c5f1&pid=100005&rk=1&rkt=6&sd=332046441820
I'm fairly sure my holes are a bit bigger than 6mm, but I have 7 and 8mm drill bits.If you were putting 6mm dynema through a 6mm hole how would you get a sleeve around it? Are the holes in your rail 8mm? mine are not. Or would you go down to 4mm dynema? If so would that be more likely to suffer from abrasion elsewhere along the rail. IE from a sheet rubbing past a single point
