Can I fix this?
Beneteau381
19 Nov 2019
As the heat exchanger has freshwater/antifreeze in it might not be a problem.
It might not BUT it is in a salty atmosphere. Also the heat exchanger is a big heat sink and I doubt that a diy propane gun could get enough heat in to the casting to enable zinc soldering.
Bite the bullet, get the heat exchanger off and do the job properly
rogerthebodger
3 Nov 2001
TIG argon?
Yes If you have the skill and aluminum filler rod.
I generally use TIG argon for stainless steel melting the edges together.
If I need to fill the joint, I tend to use MIG, so the filler rod is fed into the joint making welding easer. I have both 316 spool and an aluminum spool and gun.
Different welders have their favored technique
snowbird30ds
30 Mar 2016
Norfolk broads based, coast when time allows.
Measure the OD of the filler stub where it enters the header tank, if it will take the 1 1/4" bsp thread talk to bowman about a new neck and tap it out to suit, could be done in situ, a hacksaw blade down the inside of the stub and it will likely come out out easily by colapsing into itself.
It needs fixing so may as well try easiest way first, any welding will need to be pristine clean first and it will have corrosion in the leak, same with just filling with epoxy.
NormanS
10 Nov 2008
Some years ago I had the same problem. I was able to buy a new fitting with a simple two hole flange. I chopped off the old leaking one, with a dolly grinder, and ground a flat face on the heat exchanger. Drilled and tapped holes for studs. Job complete.
galeus
12 Mar 2005
Ipswich
So this is what happened next
In the end I decided to get professional help to fix this problem and it turned out to be a good decision.
I got Antony Kettlety, a local engine/ob specialist to have a look at the problem. He removed the heat exchanger and took it to one or two specialists, none of whom were confident in a brazing/welding repair, so he took it back to his workshop and put it on the back burner. Within a day or two he remembered he had an 'old' Yanmar heat exchanger kicking about and managed to remove the neck of this and by enlarging the hole left in my heat exchanger when the neck had been removed managed to press this in place very well and he considered it a good fix; for good measure he applied some weld/type epoxy to the joint as well and then pressure tested it. I asked him if he would clean the tube stack whilst he had it and he told me (sent me pictures) of a terribly clogged tube stack. Whilst he was gaining access to this he sheared 2 or 3 studs which he had to drill out and helicoil. I think drilling out the broken studs (out of alloy) would be a nightmare and especially if it was still in situ. He's ordered some new gaskets and O rings and will put this back next year. It will give me chance to paint behind it first. I think if I had started to try fixing the problem myself I would be wishing I'd never started.
