GGC
Can I clean a waterlock? If so what with?
I suspect it is leaking/ perhaps a pipe is leaking or damaged. There is oily deposits in my bilge. Engine working OK and water coming out of exhaust (no steam / smoke)……but I’ve definitely got oily deposits after a day out on the water and using the engine. The muck could of course be coming from something else. I’m not losing oil from the engine. But definite smattering opposite the waterlock and on the external surface of the waterlock.Should be no need to clean - as suggested if it is contaminated then there is something wrong. It only holds salt water and even though exhaust gases flow through it that should not result in deposits.
