Meps1983
Active Member
Evening folks.
Just a quick one really regarding a perished hose really. One of the hoses coming from my engine has perished/cracked where it goes Into the calorifier unit itself. This was flagged on the survey when we purchased and I've only just got onto doing the repair as its not been leaking.
Question is... if I remove the damaged pipe, remove an inch or so and replace it. Will I cause air pockets within that cooling circuit that will need bleeding of some kind? I'm new to these water heaters and larger engines. My engine is a mercruiser 350 mag mpi and it'd an attwood water heater. I'm not sure if the pic has worked but it's the pipe labeled "C" on the unit and is clearly perished. Any guidance would be much appreciated thanks.
Ben
Ben
