Overandunder
Hi all - my first 'big boat' was purchased a couple of months ago and I'm still learning the do's and don'ts of it's features (eberspacher and pressurised hot and cold water - all factory installed) - I've not had experience of these before.
Although I understand the basic principle of the calorifier (and have searched the forum), I'm after some advice on the basics really.
1. Presumably the engine normally circulates the hot water through the calorifier when running - or do they usually have a dedicated pump ? The unit on mine is buried under a fixed plate at the bottom of a cockpit locker - so not easy to access.
2. I was warned before I bought the boat not to 'put anything from the fresh water tank into your scotch'. This is a plastic Flexi tank with stagnant water therein. If I were to empty this fully- does the calorifier retain enough water to prevent overheating- i.e if I undertake a long passage under engine will it be ok ?
Sorry for the very basic questions but I'm learning on the hoof here - and want to avoid any potential foul up.
Boat is a 2006 Jeanneau SO 29.2. Any other tips greatly appreciated.
