Praxinoscope
.At our local tip there must be 50 calor gas bottles of most sizes. Obviously Calor cant be bothered to collect them.
Our local tips specifically exclude gas bottles
Did you read the thread? FloGas do a 4.5kg with almost identical dimensions. Many people have commented on this.Looks as though those of us with gas lockers built for 4.5kg bottles will have little option other than fill our own from larger cylinders.
Calor statement
… or simply swap to Camping Gas cylinders. Yes more expensive weight for weight - but typically ours lasts at least 40 days on board, so perhaps £50 extra per annum. Hardly the most material boat costLooks as though those of us with gas lockers built for 4.5kg bottles will have little option other than fill our own from larger cylinders.
Calor statement
our local farm shop has 907 full gaz bottles in stock , called in this afternoon to exchange , they wouldn‘t take my rather rusty bottle in exchange , it has been in the bow locker and get wet with sea water from time to time . they said calor gas won’t accept rusty bottles . One of the reasons I have been given in the past for the excessive expense of replacement 907 bottles is that they are de rusted , pressure tested and repainted every time .
not sure where I go from here to obtain a replacement bottle …. Any thoughts or suggestion
Chris
Thats bad by the firm. I've got a bulkhead marine regulator so just need to change the fitting on the hose when I actually get round to changing bottles. I have acquired a 7kg calor bottle (need to collect) so I can see whether it will fit in my gas locker. I can do all the measurements I like but still prefer the actual item for making the final decision.I wonder how many of the regulators being swapped out are “marine” ones. Mine certainly wasn’t and was fitted by a professional boat gas firm.
My problem is that the height is around 500mm so want to make sure there is room to play ....I did all the measuring I liked.... and I know what you mean by it nice having the physical item to hand.
Already decided though that a 7kg cylinder at the quoted height of 495 mm was not going to fit into the under seat gas locker that only has 450mm height available.
Mine is that the boat is in Sweden with two empty 3.9s on board. ?My problem is that the height is around 500mm so want to make sure there is room to play ....
Yes, Campingaz is a screw on from the top, FloGas is clip on. I think both are relatively standard while the Calor ones are quite unique even within the Calor rangehave i understood correctly that Flogas need one sort of connector (different from Calor of course) but camping gas need a different one again?
Give it a clean with emery paper and get a cheap blue aerosol paint spray and you have the something they will take.our local farm shop has 907 full gaz bottles in stock , called in this afternoon to exchange , they wouldn‘t take my rather rusty bottle in exchange , it has been in the bow locker and get wet with sea water from time to time . they said calor gas won’t accept rusty bottles . One of the reasons I have been given in the past for the excessive expense of replacement 907 bottles is that they are de rusted , pressure tested and repainted every time .
Chris
Can you raise the seat by two inches?the quoted height of 495 mm was not going to fit into the under seat gas locker that only has 450mm height available.
