Pladdatoo
Am undertaking a bit of a re-wire, so have a few questions to ask. I am looking for some best practice advise, so please be patient, I am keen to learn and do it well and don't want to just hand it over to an expert and not become intimate with my boats electrics.
Apart from replacing old wiring (some of which appears to be domestic household 3-core),I am installing a Nasa Battery Monitor, along with a VSR (I am on a 1xhouse/1 x starter config). This requires a bit of alteration to my battery cabling as the current setup is an 12AB switch. The problem with that setup is that people tend to switch it off when the engine is running!
So, I know I need to run new cabling to the VSR - with runs now shorter than previously (max about 1 metre) what is the minimum cable grade I should use? I intend to get the local auto electrician to make them up.
Also, I will need to pull 12v from the battery up to the switch panel...what is the best arrangement to tap onto the battery? I was thinking about bringing cabling up to a Positive bus bar and from there taking feeds into the switch panels. Again, any suggestions of nice ways to do that?
I gather that the BM2 requires no other cabling off the house battery's neg terminal. I currently have the Eber neg on that and also the main neg for the domestics. I want to keep the Eber on the that battery (to preserve the starter just in case it runs it down), where to I get my neg from for those?
What grade cable is recommended for general domestic cabling? Is 15/16 awg OK for short runs (<1metre) with nominal load eg for nav lights, radio etc).
Finally (for the moment), I intend to use 3 battery isolator switches (701's)to be able to separate the supplies, for those with similar set ups, do you use bars to join these together or cables?
Many thanks in anticipation for helpful guidance. Oh and yes I do have good reference material, I am looking for some practical suggestions and ideally some nice photos/illustrations to make real what I have in my head.
Cheers
Cheers
