dazlindazza
New Member
Just thought I would share a recent expereince with everyone for what it's worth.
I recently bought a boat through a broker at a fairly substancial amount of money so of course I ensured a survey was carried out on the boat which included engine inspection and sea trial.
Following the sea trial and just as the boat touched back alongside, one of the engines stopped due to that it had run out of fuel (previous owner being tight I guess). Obviously the owner put this right although my surveyor reported that the engine was eventually re-started but it did take the seller some time.
I should note that the surveor reported both engines as good conditon without any issues or leaks.
A few days later, I completed the purchase and went to collect, all looked OK after start up so we started the 5hr passage home. About half way home I checked the engine room and there was a lot of diesel in the bilge of said engine and it was clear that it was leaking from the injector feeds (not be tightened properly following bleeding through). As I had tools with me I managed to retighten and resumed the journey home.
Once home, I examined the engine and noticed there was oil sitting around one of the injectors. After a bit of investigation it seems oil was coming from around the injector and when looking a bit further the green paint on the injector clamp nut was all chipped and missing like someone had a spanner on there very recently where as all the others had a floorless cover of paint. To me it seems that perhaps when bleeding the system through the owner didn't know what he was doing and undid the wrong nut.
Obviously I went back to the broker as there was a clause in the sale and purchase agreement saying the seller has to put right any issues which develop before collection and it's clear by the fact that the surveyor documented no leaks to the engine, then it subsequently running out of fuel and having to be bled through that this was as a result of that. The seller denies this of course and the brokers are not interested and have told me that if I want to go down the breach of contract route thats for me to persue through legal action.
So in summary, it would seem that having a survey is to some degree pointless as unless you complete on the purchase and take the boat there and then, the seller can do anything to the boat and there is no come back.
A bit like going to buy a car and when you look around it you can see it's got 4 brand new tyres so you put your deposit down. A week later you go to collect the car but the garage has changed the tyres for 4 old worn out ones.
