Bravo 3
robinstall
26 Sep 2004
South Wales
I wonder if anyone can help!!
I have recently matched up a BMW D190 straight six with a Bravo3 sterndrive.
I feel the gearbox shaft has located into the engine ok but when I look down from the top of the engine I still see part of the shaft and the engineered ribs of the shaft, giving the impression the shaft has not gone in all the way.
Is this ok or do I need a longer shaft as the gearbox is sitting true and everything seems to be working ok.
duncan
Home mid Kent - Boat @ Poole
When you say 'gearbox shaft' you mean the BIII drive shaft?
This splinned shaft goes into a coupler that takes quite a load; especially when connected to diesels - most use the steel coupler rather than the basic alloy one used by the mid range petrols (5/5.7 units).
I would have thought (ie don't know for certain) that the less shaft in contact with the coupler the more likeleyhood of problems in this area. It is a 50hr maintaince item for greasing which highlights it's importance in the powertrain.
I would involve a professional opinion on your particular set up.
<hr width=100% size=1>madesco madidum ..../forums/images/icons/smile.gif
