CJ13
Has anyone tried using Braided Dyneema Fishing Line as Whipping Twine?
I don't think it would need waxing to make it slippy as it's naturally slippy, but waxing to allow adjacent turns to stick together is probably a good idea.Not tried but whipping twine is waxed for many reasons... slips through the rope strands easier, holds the whipping together better afterwards..
I guess if you wax it first, it'll perform nearly as well in a whipping but seems a bit of a faff (and a mess) keeping a thing of beeswax handy to pull it through first.
How well does it work when you try?
It needs to be elastic if you are using it to serve over a rigid object, though. I agree that is a less common requirement, but it does come up from time to time.It does not need to be elastic as you can use the rope end (that you are whipping) as the elasticity - you compress the rope end as you whip (hence why it is hard on the skin and flesh). If when you finish whipping you can secure the ends of the thread used for the whipping by sewing it through the rope - it will be secure
Jonathan
