stuartwineberg
Sidepower, twin prop with dome anode on the boss of the prop. Prop shaft has female thread into which goes an allen bolt securing the anode. Had divers down during lockdown to replace. Boat now out of water and cant shift the allen bolt to the extent where I have snapped off the(plastic) handle of my allen key. Prop is some sort of composite and access is restricted due to the tunnel. My concerns are risking snapping a blade off the prop as you have to jam the prop against the tunnel as you try to unscrew the bolt to stop the prop turning. Also concerned that if I apply heat to the bolt I might melt the prop. Cant use impact tools as it would certainly damage the thruster leg. Any suggestions?
