ghostlymoron
It's time to start a new thread unless your just seeking a record number of posts. Which boat has a new skeg and which the rusty keels?
My money is on that not happening. Will you be putting in a practice one on Selkie first.
We’ve had an utterly bizarre definition of efficiency involving the second hand price of an engine. Marine engines are described as overpriced and obsolete. We’ve learned that the world is spending billions and racing to achieve hybrid drives for yachts, yet Greg is going to build one successfully with no prior knowledge, from mismatched components obtained for little money from eBay. Requested advice and counsel has been given freely by knowledgeable and expresienced professionals but it has been dismissed.
This is a parallel universe thread to the Steel boat postings by Bret Swain. Is this your Alter Ego, Greg ?
There is always the option of installing a M-Power engine. The 46hp MP-446 complete with PRM125 retails at £4,722 including vat. These are very robust and reliable, perfect for the marine environment. for full details visit www.marine-power.net
The only way Oddity will see any blue water is if Greg sticks a hose in through a hatch and squirts some blue bubble bath in
I wouldn't put anything past him. It just gets more bizarre. First he bought a boat that everyone told him he'd never do in the time scale or budget (haven't heard much about that lately) then he buys another to practice on. Now he talks of getting the first one ready again and sailing off into the blue yonder (or motoring at 2.5 knots for up to 2 hours) but also says once he's got Oddity done he's going to put an electric drive into Selkie. You couldn't make this up but someone is having a good go.
By the way I was just looking for advice on Props.
I gave you a hint in #1122.
I take it that you'll be keeping the car gearbox (albeit with a welded up diff) so you should find a ratio to suit a very slow revving engine and a normal speed prop.
Why not keep the diff, complete with half shafts, and fit paddles?
We actually thought of fitting 3 rows of oars and making it completely green but alas we were told that the Trireme model of propulsion was outdated and probably illegal. Plus it costs a fortune to feed the rowers even on scraps and the drummer charges an absolute fortune.
Glad that you explored that possibility. It's good to have an open mind.
There can and there is. A LUMP of cast metal at 6k a pop plus bits and pieces more expensive then the price of Unobtanium from the Planet Pandora justifies it completely.
Sailing UMA did a purely electrical drive but failed at installing enough battery power to make it really usable and had no regeneration on board.
We’re going to have some Solar generation but we’re counting on starting the engine for longer runs so we don’t deplete batteries. 2 Examples: Lisbon coming out into the Ocean it’s a 2-hour thing and winds can be pretty messy because of the south cliffs and where we have Selkie moored that takes 45m to reach Gosport. At both these places its seriously busy and you do need to be able manoeuvre at short quarters and need motor. In Lisbon you will also need motor to sail out in safety because of swell /wind/ current.
I have not yet looked properly at regeneration with prop to have any form of opinion that matters. Some do it but that does not make it a good thing. We’re looking at advantages and disadvantages of everything and if we have a fixed prop that can be used for regeneration and we can regenerate a good amount its certainly better then paying 3k for a small prop generator you can hang on your transom. We may have the prop and not the 3k. Its all about economics.
Greg
It may help bring clarity to the design solution if you built a basic block diagram which identified the key components, their parameters and costs. It appears you want a sub £6K budget so say start with a £5K envelope and build the diagram from the prop up. If you assumed you needed 35HP at the prop (not unreasonable) which I believe is equivalent to around 26KW and work the block diagram up from there
The problem you have with regeneration is that with a short monohull and a dedicated ‘regeneration’ propellor you need to be averaging 5knots + before you generate anything remotely useful, If you were in a CAT then you would be likely to be sailing at a much higher average speed and thus regenerate useful quantities of power. A propellor optimised for regeneration will be rubbish at pushing the boat through the water.
