Scotsailor
N/A
75 hp in a 22 foot Newbridge boat is ridiculous … I had a Newbridge Virgo Voyager and 9 up was great
Greg
I have a Westerly Fulmar, which is 32ft and weighs 5½ tons in normal loaded trim. The original engine was 24Hp and has been re-engined with 28Hp. I very rarely use full revs and cruise at about 2,200 rpm compared to full revs of 3,400 rpm. The later Westerly Storm was 33ft and was fitted with only a 18Hp engine.
If you are intending to sail mainly, rather than motor, then do fit a folding propellor. Your boat speed will increase by about ½ to ¾ of a knot. Over long distances that makes a significant increase in performance and shorten you sailing days or enable longer distances to be attempted. If you sail across the pond, then you will cut days off your arrival time.
Your boat will probably weigh between 9 and 10 tons. The idea of a 75Hp engine sounds too large even if used solely for power generation. I would suggest not looking at car engines, but small industrial units made by Kubuto or Misubushi. They will be lighter, which is why they are used by many marine engine companies as a base unit. Parts are also widely available around the world, but some older car engine parts probably will not.
I think what he's doing is planning to use a cheap secondhand car engine. Not a bad plan and very doable.
There must be some pretty small and fairly light units from contemporary cars which will certainly be a bit more fuel efficient than most contemporary small marine diesels. They're not going to be particularly happy running at low rpms day in day out, but as long as people keep crashing cars there will always be cheap spares around. Whether the associated electronics are quite what you want on a boat will be food for another few dozen posts...
ps. This is from someone who's putting a Ford EcoBoost 1 litre engine into a Land Rover, so I do feel some sympathy.
There can be no economic benefit or logical argument for a diesel electric hybrid drive in a small yacht. UNLESS you inherited all the equipment necessary for no cost. I think there is a case for electric drive alone if it meets your needs (see Sailing UMA on YT).
There can be no doubt it is an interesting technical exercise but to then translate that into reality at your cost is indulgent and foolhardy.
Regenerating electrical power on a small (slow) monohull via the trailing prop is minimal and insignificant to needs.
I'm sorely tempted to use my favourite word "nonsense"
People who have actual, real, boats, and who use them are giving some real World figures, but on planet Greg that counts for nothing.
I'll add my figures. My boat is 35 feet and weighs around 10 tons. It is fitted with an old tech 42hp diesel engine, a Mercedes OM636. It will push the boat along happily at 1600-1800 RPM. If i run it anywhere near full speed the prop cavitiates and it starts to bury the stern, classic case of overpowering the boat and trying to exceed hull speed (as reported by others here).
I'd like to see some of Gregs figures for this 75-85hp engine/generator for charging the batteries. How does one get all of the power that you could generate from such a large engine into the batteries ? Magic ? Mirrors ?
A small, 3 cylinder, 25hp engine, running at just 1500 RPM will run a 13kw 240v AC gernerator. That's enough electricity for a small house.
How much does the 75HP engine, gearbox, generator and attendant batteries weigh ?
Ye gods. Just noticed this thread was resurrected after I'd last checked out about a year ago. Pretty sure it had gone diesel electric is the way, no it isn't, a 300Tdi is the way as it needs to be simple, now we're back to diesel electric and waaaaay too much power.
I cannot believe that you are seriously considering a DIY diesel electric system for a blue water boat, you really need to apply the KISS principle here if that's your intended use. There's an electric narrow boat based near me which is apparently nothing but trouble, and the worst that can happen there is you drift a few metres and then bang some stakes into the bank you've just nudged and put the kettle on.
Why don't you investigate a simple engine that will run off chip fat or similar? Or just installing a non-turbo VW diesel if that's the engine you want...lots of the Arvor range use them. It sounds like even with the hybrid system the diesel is waaaay to large...remember diesels like to be worked fairly hard, if it's ticking over with no load you'll have a world of problems.
What exactly do you need gigawatts of electrical power (non-propulsion) for anyway? A competent skipper will manage the boat so power use is minimised anyway...and if what you need all that power for is so vital what will you do when it inevitably goes wrong in the multiple ways that a complex system can?
My own boat is 33'10" overall, and whilst undoubtedly lighter than Odyssey, relies on a 19hp Volvo, which, to be honest, is perfectly adequate.
How much weight does 750 L of fuel weight?
Off course nothing of this works for boats…and yet the whole world is literally spending BILLIONS racing to it.
Well spotted :encouragement:
Whilst we're rambling about inneficiency, how many horse power worth of electricity do you imagine a 75hp engine would produce, if it was coupled to a properlay built generator ?
638.1 kg
But what's that to do with anything ? Who carries 750l of diesel in a 33 ft sail boat ?
My sailboat carries 100l of diesel, i don't use a tankful in a season, i use the sails.
Which 2007 car engine are you planning to use ?
How much power do you figure the motor will need to produce to push the boat at 4 knots ?
How many a/h of battery capacity do you plan to install ?
How much will those batteries weigh ?
How much diesel do you plan to carry to recharge the batteries ?
Paul although a good question it may not be the right one for the situation. If we use a bicycle dynamo that engine will only power a small light bulb.
There are more important questions to be asked, like how much power do we need and what generator are we going to use. Those are the questions that need proper answers. Not how much I can produce with that engine because that is purely an academic question.
We’re not after how much can we produce but searching for the how much is it going to cost. What are the cheaper ways we can use to achieve a solution that although not perfect academically, will allow us to power the boat. I have no problems with the engine being overpowered for what we need. I have more problems with Diesel engines at low RPM’s and how do I solve that.
I will post all of those in HIGH detail when we get to building the system which will be around March.
Why not answer them now, before you get stuck in and find it's all bollox ?
Answering them might help you to realise just how much bollox.
My money is on that not happening. Will you be putting in a practice one on Selkie first.I will post all of those in HIGH detail when we get to building the system which will be around March.
