srah1953
Thanks for all the comments. I would use a CO alarm. I was just wondering was there something physically smaller than a super Ser. I know it's not ideal .....
Many years ago I purchased a LPG catalytic heater that claim the do not produce any CO.
Never used it as it's never cold enough where my boat is
Mr Google says this
Do catalytic heaters produce carbon monoxide?
Catalytic heaters do not produce carbon monoxide. This is because they are not creating any gasses. While they can use natural gas or propane, catalytic heaters only speed up their chemical process rather than combust it.
I know they consume Oxygen so must be in a well ventilated place
Any comments from other forum members. I am really interested.
Nowadays I'd look at propane or diesel chinaspachers as the initial cost is not dissimilar and they produce much more pleasant dry heat, albeit without the option to sit in front of the glowing fire.
Thanks.Catalytic heaters will typically produce carbon monoxide at 50 ppm when run in a low oxygen environment. This won't kill you, but still isn't great, as no amount of carbon monoxide is good for you. The standard for maximum allowable exposure to carbon monoxide in the USA is 50 ppm over 8 hours.
What about your insurance?I know, but people on here quote them selectively, as I said, no regs for us!
My insurance policy saysWhat about your insurance?
Do they approve gas bottles inside cabins?
So given that bottled gas is heavier than air, how do you ensure that the "gas locker" if it is the cabin, is vented to the exterior of the vessel unless you have a hole in the floor, which is very unlikely!My insurance policy says
so it looks to me as if it comes down to "the approved British Standard and other recommendations", which is pretty broad. There would be no gas locker and a gas container inside the cabin could be secured. My last boat had a Camping Gaz stove with the bottle mounted directly under the stove ... not many of that sort left now, I think.
You don't. But if there is no gas locker ...So given that bottled gas is heavier than air, how do you ensure that the "gas locker" if it is the cabin, is vented to the exterior of the vessel unless you have a hole in the floor, which is very unlikely!
We had one of those for a while but the cost of the fuel "white gasoline" was horrendous.Many, many years ago, we had a catalytic heater on a small boat. The heater was a Danish "VN" which burned some sort of purified petrol which we used to buy in 5 litre cans from a chandlery in Maldon. To use it, the tank was filled with the special petrol, then I poured some meths over the top and set light to it, to heat the catalyst. Once it got warm, the catalytic combustion continued. At the time, it didn't see particularly risky, but we were young and foolish!
Dont need to, the regs refered to are only applicable to canal boats. A red herring argument.What about your insurance?
