Both engines sweet
iangrant
By the Sea
but the starboard engine has a slight vibration at 1100 rpm, just a rough spot it's not too bad at all really.
At all other revs it is so smooth you wouldn't know it was running. Full power full boost all fine, no smoke when warm.up to temp as usual. Am I just being fussy as the port engine is smooth at all revs. Could it be the prop I wonder as one blade was slightly out of shape on the tip.
Looses a wee bit of cooling water but I think it's blowing it out of the cap.
Ian
omega2
17 Oct 2002
Essex Bradwell UK
from the start but I think the engines were not as smooth before I changed the filters.
Ian
Our two do not run sweetly together, but when on either one solo no shakes, when both are going it's a case of doing a balancing act, boost pressure gauges help, more accurate than the rev counters.
