PaulRainbow
A quick rummage around the garage has turned up 2 lengths (1 x 3.4m and 1 x 1.7m) of what looks to be tinned battery cable of approx 35mm. I've got crimp ends, a hydraulic crimper, a VSR and a new negative post on order.
It's not the full re-wire I wanted to do, but as I'm positive (groan...) that the issue is on the earth side of the circuit, it'll do for now. The 1-B-2 switch will live on for the time being, but if I wire the VSR up and ensure that I switch to domestic as soon as I've started up each time, I should be fine.
12v DC is positive and negative, no Earths
The VSR is a step in the right direction, at least it cuts out the need to fiddle around to get the batteries all charged up. Two ways to do it with the 1-2-B now ;
- Designate the batteries as "engine start" and "domestics". Start with the engine start, then switch straight over to domestics.
- Designate the batteries "emergency start" and "batteries". Use the batteries setting for everything, the emergency start does what it says on the tin.
Either way, the VSR will take care of charging all batteries, with no user intervention required.
