Tranona
I think I need some clarity on boat size, that seems to be the most varying advice here. Some are saying any seaworthy boat will be fine, whereas others are saying it can only realistically be completed in a 30+ footer within the 3 month time scale.
My plan was to spend £5k on a boat and spread the cost of the refit (<£5k) over 6 months to a year. If I was to buy a larger boat, I'd have to wait until next year (at the earliest) to purchase, which sets everything back. I would also like a simple boat that's built well, as there is less to go wrong and parts readily available/cheap.
I think the main question is, can I get around in a Hurley 22, Corribee etc within 3 months? If not, what would be the bare minimum specification (geometry and structure, not internals) of boat to work from?
Don't get me wrong, even though I'm doing this on budget it doesn't mean I'm after the cheapest boat out there- I'll work up from that baseline specification as necessary.
If it turns out it isn't at all realistic, then I guess I'll have to wait a few years and save for a decent yacht.
The basic issue is that you are setting a target that is difficult to achieve whatever the budget. The boats you are looking at (and can afford) were not designed for doing what you want to do. That does not mean they are not capable of doing the voyage, just that setting a time constraint such as you are means that you have got to be prepared to go out in conditions that are unpleasant and uncomfortable - not just occasionally, but as a matter of course if you want to keep within your time limits.
So, it is as much about your ability to cope with adverse conditions as about the boat, and whether the achievement is the source of the pleasure, rather than the journey itself. Your choice of boat if achieving the 3 month objective is key, is the boat that can maintain the highest speed in the worst conditions that you can tolerate.
On that basis I would be inclined towards the fastest most spartan boat, and probably the nearest that has been suggested so far is something like the GK24 or the Achilles rather than the Folkboat style. Light weight, long waterline and big sail area - it will all be uncomfortable, but you can always throttle back and actively sail to make the best progress in any given set of conditions.
