VicS
No its not a Caprice.
Superstructure wrong
Sheerline wrong
Sheerline wrong
Confused of Norfolk here, Dylan is this a complete re-write of the normal Dylan mantra, buy anything and have fun?
I havn't seen you suggesting big expensive boats for novices before, or have I just completely missunderstood this post?
OK maybe not.Sorry to get back to the original question, but could it be a Prelude?
The windows don't look quite right though.
OK maybe not.
What about a Seamaster 19?
http://www.seamasterclub.org/images/boats/sailers/sms19/ishtar1-500.jpg
Did Seamasters have a bilge keeled version? I know they did a drop keel version in the Seamaster23, I nearly bought one before I spotted my Westerly.
ianat182
Nope. I was wrong about the windows. The OP's pic the after end of the window is not vertical whereas the Seamaster has vertical after window ends.
Yes
from the website where DanTribe found the picture
Designed by Laurent Giles & Partners in 1970 this sloop was available from the factory in many forms:
fixed keel with centre plate, fin keel or bilge keels.
But as LS says they are round bilged....... the hard chine may be an optical illusion in the original picture but if its really is then that is the Seamaster out of the frame.
No closer to recognising it I am afraid.
Pretty old I should think. Older than any info I have that might ID it.
The transom looks as though it might have been based on the design of a motor boat hull and the hard chine is typical of early grp boats built by taking a mould off a plywood hull.
I doubt if its sailing performance will be anything to write home about but you never know. Hard chines can get a good grip on the water and give a good windward sail. If it carries enough sail it might go reasonably well.
Trouble may be that when the time comes to sell you might find that difficult.
A well known and popular class would, on that score, be a more sensible first buy.
Yes I think you're right..thanks for the advice.
Also William H was right too.. I sat in it and I think 18 ft would be good for just me and a Frey Bentos, but if I did want to take the clan out it would be a bit of a squeeze.
Now I just have to find a leisure 23 bilge keel'r that's cheap as chips I do like the look of them inside. The draft difference from an 18 to 23 ft shouldn't be that different should it?
