Chiara’s slave
Foredeck crews nurse their hangovers away from hectoring skippers. Rail crew are on punishment duty. Their main job is to catch the spray and keep the skipper dry.I very much doubt that boats (or at least very many of them) are designed to trim correctly with the number of berths times crew in the cockpit.
Nobody in their right mind voluntarily cruises with the same number of adult crew as berths provided in most boats (or at least does so and allows all of them to be out of their berths at the same time!), and as few boats do we'd all be sailing around bows down and hence struggling to steer if they were designed for a cockpit full.
For racing, it's traditional to banish part of the crew to the foredeck, and part to the windward rail. (I've not done enough racing to find out whether that's for boat balancing or to avoid BO problems. )
I suspect your boat, Fred, would be OK with six adults in the cockpit (if a bit tight space-wise), but a little down at the stern.
I am advised that an LM27 (which has between 4 and 8 berths, depending on how you count them) will start backfilling via the cockpit drains if you have 11 adults in the cockpit! Fortunately, for partying purposes (though not for surviving the ultimate storm), mines an earlier non-self-draining cockpit model.
