Whitelighter
Ok ok so stern drives are harder than shafts.
Does that mean we agree I'm better at boat handling as well then
I recently drove a fair line sprint 21ft on the Trent, by about 10 mins I'd had enough! The steering system would be worn out in a year at that speed limit, and it was a duo prop leg.
An outdrive boat needs to be up to a reasonable speed to maintain a true course, a shaft drive at river speed is a delight, then again what's the point in a 200 hp 21 ft boat when you can do 6mph.
I don't know about that. The Sealine S37 I once owned had twin outdrives and that wandered about just as badly as the single outdrive Searay I had a few years before that. I don't even think it's a wind issue. I just think that pushing a hull from the back rather than the middle is inherently unstable. Its like pushing a shopping trolley; they never go in a straight lineI agree single outdrive boats at slow speed are a nightmare. Twins much better though. In a cross wind in a twin o/d it's easy enough to vary the revs so that the boat stays in a straight line.
The boat was almost brand new (ex dealer demo boat) and I did ask the dealer to check the alignment. He did do that but also said that they all do that, sir. But yes I suppose its possible the drives were out of alignment despite the dealer check but other outdrive powered boats I've had have exhibited the same tendency to the same or lesser degree. IMHO its a characteristic of the drive systemIf you're wandering around all over the place at low speed with twin outdrives, they need adjusting!
I don't know about that. The Sealine S37 I once owned had twin outdrives and that wandered about just as badly as the single outdrive Searay I had a few years before that. I don't even think it's a wind issue. I just think that pushing a hull from the back rather than the middle is inherently unstable. Its like pushing a shopping trolley; they never go in a straight line![]()
That assumes all goes well with servicing.As for maintenance costs, the key is preventative maintenance, and Rafiki probably costs about £500 per year for the engines/drives, but I do some of the work myself. I think VP's are a bit more vulnerable to things like fishing line etc.
I had an outdrive explode (literally, through the casing). A new one isnt £500![]()
Rafiki is on twin outdrives, and while she is easy to handle, at displacement speeds, she is susseptible to the breeze. This is amplified when mooring, but if my alignment is wrong, I'll just go around again, and give it another go.
I don't think that shaft drive boats drive from the middle, as the props are at the stern, although not as far back as outdrives. The powertrain mass is more centralised, so the centre of mass is much further forward than on a sterndrive boat.
