At long last I have discovered the overheating problem on my new (old) lump. The previous owner fitted to the front of the engine an engine driven pump (with 1/2" connections)- I think this pump is if you have keel cooling- (The impellor is quite small).
All throughout I have 3/4" water connections up to my heat exchanger and i want a pump with a larger impellor and able to pass water through 3/4" piping. I've seen a belt driven 3/4" pump that fit to the side of the engine for this engine, but I will have a problem fitting one due to poor access even if I could get one. also I have a real problem of added an extra pulley to the flywheel
Now the crux..... 1) Is there a front mounted 3/4" big impellor pump that will fit in place of my 1/2" one. 2/ Failing that - whats the consensus of fitting an electric pump in place of the engine driven pump ???
Any other ideas ??
Any other ideas ??
