John w
New Member
Hi Guy's & Girl's
me again!
A bit of background I am thinking if I buy a Bluetti AC 200 Max Solar generator will it solve my shore power at anchor issue? So have a few questions that some of you may be able to answer.
I am not very electrically savvy so please if you could keep it simple for me to understand.
I am wondering if the Bluetti's 13 amp 240v output will power my 2011 Bavaria 36 cruiser via the shore power input socket, So this would power the whole boat ie. microwave, fridge & house bank battery charger as well as the 240-volt sockets?
Then thinking to install solar panels permanently to charge the Bluetti this would be while at anchor.
Then I could top up the solar generator charging with solar panels & the power supply charger using my existing Honda EU2200I to get it to full charge.
Some of you may remember me posting about my Honda Generator used to connect to the shore power input which gives me a polarity issue & then trips the panel input switch. So was thinking the Bluetti would give me the benefits of a Lithium battery with 700 watts of solar input & a built-in inverter of 2500 watts which I can remove if I sell the boat in the future.
I have installed an invertor on the back of the house bank batteries which is 2000 watts but will still not run things like my coffee machine Gusto (broken 2 already) & it absolutely kills the batteries just making coffee.
I could go the traditional route & install MPPT controller from the solar panels into the house bank but it still does not solve the 240 v mains socket or microwave use issue.
Question Does anyone know if I will get the same polarity warning issue using the Bluetti as the main shore power input? & has anyone tried it on Bavaria sailboat? or any sailboat?
I don't want to buy the Bluetti & plug it all up only to find the same issues with the Honda generator.
Thanks in advance John
me again!
