Bird Poo on Stackpack
Tam Lin
1 Sep 2010
Essex, near the R. Blackwater
Last winter I made a stack pack for the boat and felt rather pleased with myself, especially when I fitted it and it worked. Halfway through the season I wasn't feeling so happy as birds had been perching on the edge and pooing in the middle by the zip. I tried tying bits of string across the top without much success. Has anyone experienced the same problem and overcome it?
blush2
26 Dec 2008
It's a nice shelter for them when it's windy.
The snake idea seems to work for small birds, we had problems with wagtails. In the cockpit we put several snakes where they were obvious, and a garden net across the spray hood to stop them sitting on the coiled halyards and fouling.
However we ended up lacing the stacker by pulling the jackstays together. It was also important to tie closed the ends of the stacker to stop the little horrors creeping inside and messing on the sail.
Bodach na mara
21 Aug 2002
Western Scotland
I had a similar experience with the old traditional sail cover. I ran a piece of nylon cord between the topping lift and the top of the cover at the mast end so that it was about 6" above the cover at the point halfway along. That worked for most birds. Then one year we had the problem with one group which didn't seem to mind the cord. So I took a lot of old CDs and DVDs and drilled holes in them near the edges and threaded them on the cord. That worked.
I second Blush's experience about them getting in at the rear end. A pair nested there last spring after I put the sail back on during several weeks of shite weather when we couldn't sail. I didn't notice until I yanked up the main and saw the birds flying off along with the remains of the nest. Oops!
Ardenfour
7 Feb 2004
Port Bannatyne
mine is identical...
