Stemar
I have a 360GPH Rule (I think) bilge pump under the cabin sole in Jissel. The pipe has a non-return valve an inch or tweo away from the pump The arrangement is about a year old. Now, Even when there's water there, turning the pump on doesn't do anything until I suck on the through hull, (carefully /forums/images/graemlins/tongue.gif!), when the water starts to flow.
Is the valve faulty, or is the pump not really up to it? Due to old oil leaks, my bilges are a bit manky and recent filter & fuel line problems haven't helped. Should I expect a non-return valve to survive contact with oily water?
My local swindlery has a low profile pump (Whale brand, from memory) for about £20, again, from memory. This would actually do a better job of emptying the bilges, 'cos I could get it into the middle of the bilge, while the current one has to be offset a bit because of its height, but is it likely to be have more umph than my current pump?
Apologies if this is a bit rambling - I'm a bit brain dead after a hard day!
