Seastoke
So I am looking for a small in line pump with flex pipe each end say 15 mm , 12volt to get in nooks an fcrannies
No I want small with small pipeWet and dry vacuum cleaner will get water from nooks and crannies
I have got a manual pela which does work , but it’s to big to hold pipe and pumpsecond the Pela option
Fit a 1/4 turn valve in the suction line, then you can pump it ahead of positioning the tube.I have got a manual pela which does work , but it’s to big to hold pipe and pump
