Oldgeezer
A bit of history as it might be relevant.
The engine is 4 years old - 120 hrs on the clock - no previous history of overheating -
Until last year when the boat was taken out by my son who didn't notice no cooling water coming from the exhaust.
The engine overheated a few times and destroyed the impeller and exhaust waterlock etc.
So end of last season, new waterlock, impeller, remnants of antifreeze drained and replaced.
It ran with no problems for a dozen hours or so before lay up.
This year, I drained the anti freeze again and put in fresh.
I cleaned out the heat exchanger (not much in it anyway)
Last week I had gone approx 1hr when the overheat alarm sounded
~Got towed back to mooring and started engine.
After 30 seconds the alarm went off.
The boatyard then installed a new thermostat thinking it probably wasn't working.
I also checked the heat exchanger was clean.
This morning the alarm went of after 20mins running on my mooring! Engine cover off so no ambient heat.
There is lots of raw water coming from the exhaust (I measured in a bucket) It wasn't warm but then I'm not sure it should be.
The heat exchanger felt cool
The thermostat housing was hot
The flexible hose that connects to the bottom of the fresh water pump was cold (is that right?)
I can only think it may be the fresh water pump - but these are very reliable (or are they)
I will contact beta tomorrow but I'm running out of ideas.
Do you have any?
Keith
Do you have any?
Keith
