Tranona
It's and old outboard with rust in tank and I have put cider vinegar in to was out then neutralise the acid with bleach so they say for motor bikes etc etc
If it is an old metal outboard tank, ditch it and buy a new one. Cider vinegar will not do anything to remove rust and crud. If you really are too tight to replace a rusting tank then steam clean it - easy when it is out of the boat. However if rust has started you are likely to cause perforations if you are too aggressive.
