Neeves
One reason we use alloy is that we do want to be able to deploy (and retrieve) by hand. I'm not quite as old as you Flica (and admire your tenacity). You, and Tranona, are an example to us all.
We carry a FX 23, which I think it too big! and am toying with going down is size (and will be trying a smaller model in the next few weeks). Its not too big because its too heavy, its about 8kg as are the other alloy anchors, but because it would hold us in a Hurricane and we are wimps and go hide, still at anchor, when only Storms are forecast. We carry textile to allow shorelines and tie to trees and rocks (If possible). I estimate the FX 23 fluke is about 30% bigger than either the Excel or Spade A80. We have never had an issue with setting the Fortress but would use it in sand or mud. In stones or medium weed either or both of the Spade and Excel.
I usually deploy from the dinghy (one anchor deployed by windlass and the second, in a 'V' from the dinghy) and we would use 15m of 6mm chain and 40m of nylon, 12mm I think. Flica - one way to cut back on weight would be to use 6mm chain, for a Med moor you do not need a G70 (or even G40) a G30 would be plenty strong enough and 6mm would save a few kgs over an 8mm.
I've only confirmed the size of the 15kg, 33kg and 55kg Rocna and to me they have the same fluke areas as the similarly weighted Mantus (set side by side) - I've not actually measured them to check for nuances. The Mantus 'looks' huge but its the protuberance securing the roll bar that make it look massive.
I'm amazed that Plastimo do not have outlets in Greece. I knew they had their issues but to cut out Greece with its huge itinerant yachting population seems like shooting yourself in the foot. I've seen Kobra's on yachts based in Greece - but never thought to ask where they came from.
Jonathan
Jonathan
