GHA
Eneloop and nitecore charger. IKEA rechargeables seem to get good reviews as well.
The copy I saw was probably about five years old - it was in my old man's house when I was clearing it. The next issue contained a not-at-all convincing explanation of their reasoning. I would have understood having "Best Buy (highest capacity)" and "Best Buy (value for money)" categories. Maybe they do now.They did exactly this a couple of months ago - unless it was a very old copy of Which I saw recently. I though they were being a bit thick really, couldn't understand their logic.
I bought a pack of "10 +1 free" Kodak AA batteries labelled "Heavy Duty" from a pound shop and they were pathetic. Reading the small print, they were also labelled "Zinc Chloride" and " ... intended for low power products." They didn't even last long in my quartz clock.I've been happy with Kodak brand from Poundland - 5 for a £1
Not all cost is in pence. Obviously it’s cheaper to screw the environment and use a thousand low capacity batteries. At some point you have to act responsibly though. I agree they should have explained their thinking but I utterly hate the idea of a 500 pack of AA batteries!if they're not comparing pence per Ah the "Best Buy" thing means nothing.
Readycell alkaline £1 for six from Home Bargains
I've used hundreds of them. They seem on a par with the major brands in terms of charge delivered.Have you tried them? Are they any good?
Not exactly the most earth shattering investment at a £1 to try a few.Thanks, I might try some.
Could have saved loads by getting rechargeables then...I've used hundreds of them. They seem on a par with the major brands in terms of charge delivered.
I tried going rechargeable a few years back. Perhaps it was my fault for getting the batteries at Lidl, but I found an attrition rate of about 20% per recharge - ie every time I tried to recharge 5 batteries, one would have died.Could have saved loads by getting rechargeables then...
Alkalines normally stay active for a long time, rechargeables can self discharge making them useless for safety equipmentCould have saved loads by getting rechargeables then...
Most modern ones work. I assume JD bought old style ones. As I said much further up the thread the modern Duracell ones do exactly what you'd expect them to do. Same capacity as a normal battery but rechargeable. They recharge in 30-45 minutes and don't discharge until you actually use them. They deal well with cold weather and don't cost considerably more than normal Duracell batteries. If you buy them "out of date" at a supermarket they are actually cheaper than normal batteries and obviously still work fine.Can anyone recommend any rechargeables that actually work?
