athertop
Hi folks,
I have been looking at a Beneteau Oceanis 46 (5th Gen, so 2005-2014 model), and have some questions that I would be grateful if any Beneteau owners or surveyors with experience of Oceanis models of this era can answer.
I was looking at the keel bolts, and see some rust which appears to be coming from under a few of the bolts - wondering if this is unusual, or if it points at possible grounding causing loss of sealing etc? I have attached a couple of pics of these bolts for reference. I also note some standing water in the keel sump:
My second question relates to the drainage channels/tunnels which are formed in the lower section of the bonded-in grid system flanges - these tunnels in my mind are supposed to be opened to allow the inside of the hollow grid structure to breathe , and allow any trapped water to escape, and also to allowing water to flow between separate bilge sections via these tunnels so it can reach the sump containing the bilge pump. In the Oceanis 46 I was inspecting however, I noted that smaller tubes had been bonded into the archway on each side of the grid section, forming a direct path for water to travel through each grid section - and in doing this, blocking the atmosphere (and any water escape from inside the grid structure into the bilge. I wondered if this was in-fact a part of the design, or whether these tubes have been retro-fitted on this particular boat. The bonding of these tubes looks a bit too rough and ready for my liking, and in my mind could not have come from the factory like this - what's more, they actually reduce the size of the passage and therefore would restrict water flow through the grid sections considerably, so I assume they were retro fitted (for some unknown reason). The person showing me the boat however, was trying to suggest that it came from the factory this way. Sadly I have not yet been able to check out another example Oceanis to compare this, so looking for anyone in here with knowledge of what the small tunnels in the lower flange of each grid section are supposed to look like. I'd be grateful for any comments. I must apologise as I didn't get a good photo of this - you can just see the arch I am referring to and the tube that is bonded inside this, linking each side of the grid section in this photo:
You will also note that the hull floor has been painted - I wonder what other Oceanis examples of this era might look like - is that supposed to just be gelcoat/flocoat, or is paint the norm - again looks a bit rough for a factory job.
Thanks folks, and best regards, athertop
