BelleSerene
I shall be doing so too - as soon as I get round to replacing the continental things. Manufacturers never put enough power sockets on boats. I shall be replacing most, if not all, the continental sockets with UK 13A sockets, and will be adding several more at floor level to power fan heaters and dehumidifiers. I shall also be adding a couple of 13A sockets in the cockpit to power laptops. But, for now, I'm having to rely on adaptors and the combination of a proper Schuko plug with a proper 13A trailing socket seems to be far more successful than those little adaptors that you get in airport departure lounges.
I'm going the other way. I really heard Gymnopedie's comment not to use travel adapters for high-current applications, and he's clearly right. Although I haven't (knowingly!) had over-heating problems, it made me scared about two of mine. So I've ordered a couple of Schuko plugs online and I'll be rewiring and the fan heater that sometimes gets used in winter, and the mains extension lead I use for other purposes on board, to plug straight into Beneteau's Type E sockets. I am happy with the travel adapters for the other uses which are for trickle charging, mobile phones etc - only really because I can't be bothered to/ can't afford to rewire them all for UK sockets.
