alancollins
Thanks everyone , particularly Plum for the wiring diagram as mine is the Leroy Somer winch.
Well something is rather odd there because the battery bank is the parent source for all power. Having the motor on just charges batteries with batteries acting as ballast. I presume you dont have a duff battery. Is there any other electric or electronic device onboard that only activates when the engine is on? I'd be interested to know. Anyway I digress. If your battery was sub par you could easily have burnt the relay by drawing more amps to compensate for voltage drop through it and would explain why it would only work with engine running. Find the relay and check to see if it's working, keep a spare.
Well done. You have just reminded me that on my 760 there is a relay fixed (not a VP part) to the back of the alternator and before my ownership somebody had removed some of the wiring to it. As my winch works no mater when the engine is running or not maybe that relay is what is/was inhibiting the winch without the engine running, as other owners report.Usually a relay in the control circuit to the foot switches, the coil fed from the alternator, so it will only operate with the engine running.
I'd look for the control circuit fuse as said, or find & check the relay
Well if they build boats the same way as they build their cars I suppose anything is possible, but I think it's odd you'd push high amperage through any switch, foot or not.
This seems common on Beneteaus. They put a 12v relay behind the alternator so that the anchor winch can only be used with the engine running. BTW this relay is in the low current circuit and separate from the main breaker. There also seems to be a +ve and -ve wire available in the harness which I assume is to cater for different supplier's winch models.I had the same issue with the Quick windlass on my 760. It turned out to be the relay near the alternator. It is a NO relay powered when the engine is running, and it disconnects the ground from the windlass control circuit. I am not sure that I am too comfortable with this set-up, I would like to be able to drop anchor if my engine fails without going to the bow and doing it manually.
An old thread, but yes, as referred to in post #30 the wire from my relay behind the alternator had been cut before my ownership which explains why my windlass will run with the engine off.I had the same issue with the Quick windlass on my 760. It turned out to be the relay near the alternator. It is a NO relay powered when the engine is running, and it disconnects the ground from the windlass control circuit. I am not sure that I am too comfortable with this set-up, I would like to be able to drop anchor if my engine fails without going to the bow and doing it manually.
My Jeanneau has the option of running the windlass with the engine off. I've always left it set to the default but did test it when installing a wireless remote. Not exactly easy to find but just a matter of opening a panel in the forward cabin and inserting a link. The link was taped to the bulkhead with a note to say where it should be connected to allow use without the engine running.This seems common on Beneteaus. They put a 12v relay behind the alternator so that the anchor winch can only be used with the engine running. BTW this relay is in the low current circuit and separate from the main breaker. There also seems to be a +ve and -ve wire available in the harness which I assume is to cater for different supplier's winch models.
Yes, not the usual Leroy one. See here Leroy Somer S3000 series windlass.pdfApologies for resurrecting an old thread here but my 760 windlass has just suddenly stopped working...
Fuse behind the helm doesn't trip and weirdly there is a beeping from in the wheelhouse when I press either of the windlass buttons.
Not worked out where the beeping is coming from.
But the windlass won't operate.
I noticed the buttons look like they need replacing - maybe moisture got in?
Looks easy enough to take out and swap in some new ones.
Not the normal Leroy it's one of these, any obvious things to look for before I call out an engineer?
Yes that's the one - thanks!Yes, not the usual Leroy one. See here Leroy Somer S3000 series windlass.pdf
