Because i usually do the washing up
Clunk
23 Apr 2022
Nottingham
On Christmas day, due to myself doing the cooking I was downgraded to drying the pots whilst my other half washed the pots. Been on the boat now for 6 months, anyway due to not staring into the sink this particular time I noticed that the amps and volts gauge were jumping around when the taps were turned on. A 12v water pump kicks on and off when taps are in use so I'm guessing this is to be expected, but would just like some reassurance that this is in fact normal.
NormanS
10 Nov 2008
how would I know if it's worth investing in one of those?
I would have thought that most electric pumped water systems on boats were equipped with accumulators. It's simply a container with air in it, which is compressed by the water pressure. It means that, for example, if you want only a cupfull of water or thereby, when you open the tap, you'll get your cupfull without the pump coming on at all. It saves the pump going on and off so frequently. Are you sure that you don't already have one in your system? If you do, it may need attention. Some are simply a small vessel, theoretically full of air, with the pressurised water connected at the bottom. Over time, the air is consumed, the chamber fills with water, and needs to be drained. Some have a rubber bladder within the chamber, which should be charged with air. IIRC mine has to be charged to about 13psi. As to whether it's a worthwhile investment, only you can decide. If you don't already have one, I think they might be between £30 and £50.
Clunk
23 Apr 2022
Nottingham
When I bought the boat the water pump was leaking so I fitted a new seaflo pump. I don't recall it attaching to anything like that.
geem
27 Apr 2006
Caribbean
I vaguely recall some pumps within the instructions (which nobody ever reads) mention - do not use an accumulator.
Jonathan
Most pumps benefit from an accumulator. It reduces the stop/starts over its lifetime. Lots of these devices measure the useable life in stop/starts so you effectively increase the life of the pump/motor
Neeves
20 Nov 2011
Sydney, Australia.
That's really helpful. ?
Simple stuff.
Just read and follow the instructions.
If the instructions say, don't install an accumulator, save your money
If I had to bet - Flojet or Surflo, but I'm on land and the pump, and instructions, are on the water.
Jonathan
Another thread where it has all been said already
Accumulator tank or not?
The answer seems to be, 'maybe', 'it depends', 'possibly'
J
Clunk
23 Apr 2022
Nottingham
OK, it does have an accumulator so how do I go about charging it?
