NormanS
It happened in August 2007.Can you point me at the report. I have a vagile recollection of that incident.
It might be 100 deg if it’s glassy calm. Ask yourself, will a C32 get knocked to 78 degrees in calm water. We had a huge kite miscalculation and got laid over about 60-65 degrees, in a 1.5m chop. Huge amounts of water went inside, knives were used to cut the sheets, order was gradually restored. Without cutting the sheets, I have little doubt she’d have sunk. A very unpleasant situation.
Downflooding angle and the angle at which righting moment becomes negative are two different things.So it's an anecdote then. That's ok but 78 degrees sounds very objective.
Actually the figure is probably nearer 120deg and like almost all yachts of her, and many other types, at 90 she would floating on her side with the companionway well clear of the water.
Contessa 32,s have been knocked flat and beyond many times. In the high Arctic, in the latitudes of the Great Capes, In the Roaring Forties.
If you actually managed to sink one off Spithead it would be notable feat.
Finding anything on the maib site has become a pita since it was subsumed into the .gov styling.Can you point me at the report. I have a vagile recollection of that incident.
I could not watch the video that h20man had linked but I think this is available on The Sun website.
CCTV shows superyacht engulfed by storm as local says it 'vanished in 60 secs'
Capsize of army cadet force rigid raiding craft with loss of 1 lifeIt happened in August 2007.
A tragic accident. I'm not sure what lessons could be drawn from it either.
I don't think you need to wish you hadn't posted, it was interesting stuff. This thread isn't in my view wild or morbid speculation, but experienced sailors considering ahead of the official report what might have happened - with a view to avoiding it happening again.And now I wish that I hadn't posted those links... My thoughts are with everyone affected.
22 tonnes of mast must take quiet some counterbalancing though...
We didn’t stop to measure the angle I can assure you. But, since none of us fell out of the boat, it wasn’t 78 degrees, but a lot more than you’d want to sail at. Being pinned by the spinnaker at that angle allowed a lot of water in, probably 18” at least over the cabin sole. The boat came upright with the kite released, as you’d expect. It was about 2 miles off the Needles btw, 25-30kn of wind. Only a small spinnaker, but the boat rounded up. A knock down I appreciate is not an issue. Scoop a bathful of water in, worst case. Being down for a minute or more is what is dangerous, which is very likely what happened to Mr Lynch’s boat.So it's an anecdote then. That's ok but 78 degrees sounds very objective.
Yes, the mast is huge - but so is the yacht!
Relatively, it’s twice as heavy as ours, and we are ultralight, displacement wise. About the same height ratio. No, it’s still massive.You're right... a 22 tonne mast on a 450 tonne boat...
It doesn't sound so bad now...
