pcatterall
Just checking the batteries on my ( new to me) 3 year old van. The hand book assures me that the batteries will be checked as part of the annual service. On the transit there are two batteries, one seems to be for ancillary equipment and one mainly for starting, they are both under the drivers seat. There are individual caps for each cell and some are under a big metal security frame, 3 difficult bolts to undo and difficult then to remove the frame. There is then only access to the rear battery caps, to get at the front battery one would really have to remove both batteries.......... what a pain and I bet they have never been checked!!
So we come to the real reason for my post and I have had this question with my boat batteries.
Looking into the cells on my vehicle batteries I can see a sort of flat plate and there is a very small amount of liquid ( about 1 or 2 mm) above this plate, is this ok or do I need to top up a bit?
On the boat there seems to be a wafer visible and I guess I should be ensuring that this is also just covered? This is a mirror and torch job to see the plates and I guess I should invest in a bottle with a tube to aid top up?
It seems to be a bit hit and miss and I suppose that if I add too much water I will have the wrong SG of liquid?
Do we rely on guess work/eyeball or should we test the SG each time we top up?
