jakew009
For me, leaving the DC switched on whilst we are away from the boat is a No No No No
If you must have a fridge on whilst you are away, why not arrange for it to be powered by the shore supply.
All mine are.
Waeco supply fridge power unit that will power a DC fridge from both 240v and DC (12v / 24v).
It automatically switches from DC to 240v whenever the 240v is connected.
Use one of these and SWITCH THE DC OFF when you are away.
Then, if someone disconnects your shore supply whilst you are away, your batteries won't discharge.
When you are on board (with your DC systems on), the Waeco power unit will automatically switch from 240v to DC when you go cruising.
And then switch back to 240v whenever you are plugged back into shore supply or running off generator.
These Waeco supplies are used everywhere - they are designed for the job.
They have a few different models, depending on the size of your fridge.
Why are you against leaving the DC system on?
