wonkywinch
Of course in practise that rarely happens on a sailing vessel at the end of the day as the engine is invariably started with all the electronics running as you drop sails, enter your harbour etcI am fairly sure that the manual for my B&G plotter advises exactly that.
My boat has separate engine start, thruster and "domestic" batteries which are normally isolated from each other. If the engine start is from the same supply as the equipment then there is a risk the battery will drain and be insufficient to start the engine so this situation should ideally be engineered against by use of an isolating switch.
