coliholic
On my motor boat I have two separate banks of batteries. One single 135AH battery is recharged by the port engine and supplies just power for starting to that engine. Two 135AH batteries are connected in parrallel and are charged by the starboard engine and provide starting power to the stbd engine and domestic services.
I've always kept the batteries topped up by connecting to a normal car type charger running off shore power but this is a bit of a performance, opening the engine compartment, taking off the lid of the battery box, connecting the charger via crocodile clips and plugging in to a 13Amp socket, then a couple of days later having to go back on board to change the connections to the other battery.
So, I've come up with a cunning plan. I'm planning to connect a two way change over switch in the red lead from the charger and mount that switch remotely in a locker so I can easily get at it, along with a mains on off switch and an ammeter so I can see what current's being drawn by each battery. I intend to then take an output from this two way switch to each battery and then I can just switch the charger from one battery to the other. Obviously the black lead from the charger goes to all three batteries negative terminals.
Can anyone see any flaws in this?
Any chance of causing electrolysis problems?
I realise that I should really spend £200 or so on a proper Adverc or Sterling charger, but am lookinjg for a slightly less expensive solution since I've already got the battery charger doing nothing anyway.
Any thoughts please?
