Battery charging system
ecereijo
10 Apr 2003
NW Spain
Hello.
I have bought a second-hand Najad. The battery charging system consists of three batteries (65 Ah for cranking and two 105 Ah for service) charged with a Bosh K1 65A alternator, a TWC electronic voltage regulator and a Sure Power 703-4 isolator.
I want to connect in paralel the two service batteries. My question is, witha that configuration, how must I wired the batteries to the isolator?; can I let unwired the Aux2 connection and use Aux1 only?
Tank you very much.
pvb
UK East Coast
Hi, and welcome to the forum.
You are right to connect your service batteries in parallel - they will perform better this way. Your isolator will handle 70A, so you could just use Aux 1 on its own. However, as your service batteries will take the bulk of the charging current, you could link Aux 1 and Aux 2 together - this will reduce the load on individual diodes and could prolong the life of the isolator.
