KompetentKrew
Do you have a link to the instructions you followed, please?West System was applied "wet on wet" in sense that the previous layers were still tacky, but this is according to the instruction.
We didn't use acetone after final sanding.
maybe wax had come to the surface
suspect the most likely cause of your problem was either a contamination on the hull that had not been removed by water pressure washing.
Pressure washing forces water into glass fibre, it would take days/weeks to dry in my opinion.
i think it's more likely that the problem was some contaminant on the surface prior to application of the first coat
No. I apologise as I should have qualified my statement by adding “without leaving adequate time for evaporation”. This can take a number of hours because solvent can be drawn along the surface of glass fibres by capillary action and be very reluctant to evaporate.Really? By ‘prior’, do you mean immediately before application and without allowing time for evaporation ? (if so, I agree) Or do you mean no degreasing/acetone at all?
West say:
Regarding solvents for cleaning - it depends on the epoxy base. It does not apply in this case but Coppercoat uses a water based epoxy and IIRC specifically warns against using solvents to clean the surface before application.
A combination of a alkaline degreaser (concentrated ‘garage’/workshop degreasers are suitable and cheap as they dilute at a couple of capfuls per 1L of water) and aforementioned solvents (acetone, alcohol or painters’ ‘panel wipe’/‘prepsolv’) should do the job.So, is it possible to remove contamination after sanding well enough? Can it be something that even a good cleaner will not remove?
When I coated my current boat in 2009 in Plymouth I had the antifoul removed by soda blasting, removed old epoxy barrier coat to gel coat with random orbital sander, then water wash with hose to remove dust. A few days latter applied high build industrial epoxy (one coat per day) that was supplied by the Coppercoat people, then a few days later Coppercoat. When I next lifted out in 2019 to touch up the Coppercoat I had some small solvent blisters on one side of the hull that had formed between the first and second coats of the high build epoxy.As a pure laminating resin, West is towards the more intolerant end of the epoxy spectrum when it comes to prep. If you have another go, I’d recommend a solvent-based paint such as Jotun Penguard or International GelShield.
Indeed blasting itself is also cited as an effective means of surface decontamination (based on TDSs - not any personal expert knowledge!).I had the antifoul removed by soda blasting
New steel will have mill scale surface deposits. Painting over these will inevitably lead to rusting long-term. The famous SA2.5 standard requires all mill scale to be removed, leaving an even gray surface with no black spots.Was chatting with pontoon neighbour undertaking a massive (20m+) steel boat restoration in the yard about how some blasting was being delayed so that the pros could blast as much of the new steel as possible too (presumably, we figured, to quickly/effectively clean and key the substrate before coating).
