KompetentKrew
Not an expert, so please someone tell me why I'm wrong, but surely the first layer of epoxy never actually cured?
Top google hit for "how long for epoxy to cure":
So if you're using thickened epoxy to fill a hole or glue something (is this called "filleting"?) then we tend to think of it as "done" or "set" when the epoxy is hard after 24 hours, but it's not really cured.
So OP painted on the first coat, after 24 hours it was hard, but it still wasn't fully chemically cured - it was prevented from curing by the addition of extra layers on top which isolated it from the atmosphere.
With two pack epoxies, where the curing mechanism is an internal chemical reaction, full cure could take months. During the curing process, there are many chemicals reacting with each other to form a highly cross linked network, turning liquid into solid. This slowly makes it harder for any remaining non-cross linked parts to react. The temperature and humidity during the curing process plays an important role in the speed of cure, as warmth provides the system with more energy to react. So this means the curing process is faster in warm temperatures, and slower when it’s cold.
In reality, full cure is usually defined as the time it takes for the product to meet all of its required end use properties. This is usually around 7 – 30 days depending on the temperature during cure.
Epoxy based products may appear to be cured ie they are dry on the surface, but they may not have reacted fully throughout the paint film.
Therefore it is important that the recommended over coating times are followed to avoid a partially cured product from absorbing solvent from the subsequently applied coatings leading to potential problems such as but not limited to blistering or poor adhesion.
link
