kko
And what about the Coppercoat over the solvent based products?
See my previous post - 54. Coppercoat over industrial solvent based high build epoxy in 2009, still sound after touching up in 2019.And what about the Coppercoat over the solvent based products?
It is possible there was a long term build up of moisture in the hull over 40 years. However, the usage over the last seven years should have dried the hull somewhat. When I successfuly coated my current boat (described in earlier post) she was 15 years old, had been ashore for two years but had only ever spent one winter afloat shortly after launching. Survey report was that moisture content was minimal to negligible so I felt confident in applying epoxy.Ok just to confirm this peeled off back to the bare original gelcote / fiberglass ?
If so here’s a thought know-body has come up with.
The boat is 40 years old and its been drying for 10 months but the hull might very easily still have a high moisture content (the pre curser to osmosis) I haven’t heard anyone mention a tramex or sovereign moisture meter being used. From what I’ve read Epoxy coating should only be used on surfaces that display a certain level of dryness this is a different reading for tramex or sovereign meter, could it just be that the coating just wont Stick properly for this reason ???
