Bakelite or the modern alternatives...which are?
ean_p
28 Dec 2001
Humber
I'm looking for a reasonably priced 'mounting' surface that is both insulating and reasonably heat resistant. It was always 'Bakelite' or some such material that was cheap as chips, but it now seems to be very expensive and not so easy to find! What are the modern equivalents ? Looking for a few square feet and about 6mm thick, being easy to drill and work....oh and safe to use!
What is it insulating?
Tufnol certainly wouldn't be cheap as chips, unfortunately. Also depends on the finish required.
HDPE springs to mind.
I think Tufnol is the material
I seem to remember picking up a prop shaft bearing from a place in Birmingham which turned out to be the (remains of) the Bakelite factory
I thought Bakelite was literally banned retail ? Due to the production process involved or if it caught fire ?? Long time since I read about something with it.
Silly me ... it was the use of PHENOL in its production ...
Example of the dangers of Phenol :
I used to sail on a Chemical Tanker that carried Phenol from Huelva in Spain to Rotterdam for BASF / Shell Chemie. While transiting English Channel - CG used to issue regular warnings to other vessels to be aware of our passage with such cargo. We carried it in liquid form and heated to prevent it crystalising .... it was not unusual for our deck pipelines to become solid with it - requiring steaming to open them back up. We were required to wear full Hazmat gear when working on deck and only one person in close proximity to lines etc - with second clear but close enough in case of ermergency ... personal saunas we called them !
Phenol was eventually restricted in Europe due to its toxicity ..... based on large tonnages being moved.
Are you talking about electrical insulation, heat insulation or sound insulation?
There are plenty of types of plastic panel available - e.g. solid acrylic or foamed PVC. Wood/MDF is also possible. "Marine Board" is HDPE (as already suggested)
Sorry B but I thought that I'd already edited the post....it needs to be electrically insulating but also resistant to heat / burning in case of an issue with the 'electrical equipment mounted on it....the old Bakelite would fulfil all the requirements but I think Tufnol and most straightforward plastics would have issues with the heat / fire resistance...!
I was an apprentice on a major chemical plant that manufactured Phenol. Its danger is that it is absorbed through the skin and attacks the central nervous system. Indeed clothing moistened with phenol over the area equal to a dinner plate would be enough to eventually kill a man in a slow rather horrible way......such a thing happened on site to one of the guys working in the barrel park. he sat on a barrel to have a chin wag and thought he'd sat in some rain water......he was day a few days later! As a young apprentice tech who would be working on the production plant and equipment it was a tale that found its way very firmly home!
Incidently most people would have experienced Phenol through using 'Lifebuoy' soap, Phenol was the 'antiseptic' ingredient!
You can still get paxolin panels that is very similar to "bakelite" that should meet your requirements - but not cheap. You can also get various treated fire proof materials including MDF and wood
That's all quite vague.
Do you need to insulate thousands of volts? How much leakage can you tolerate?
How heat resistant? 100degC or 1000?
What mechanical properties are required?
Does it have to look pretty?
Glass, ceramics, fibre cement, plasterboard, mica,
