prv
Inspired by the other thread...
Ariam currently has a system similar to the second one ("12:1 Cascaded") on this page: http://www.harken.co.uk/content.aspx?id=3896 . Same wire strop and sheave, but the tackle is only 4:1 and uses fiddle blocks.
It doesn't work very well, because as the backstay is tightened it rotates. I guess this is the twist in the wire straightening out a little. The result is that the sheave on the end of it also revolves, and it wraps the strop around itself and the tackle.
The obvious solution is a swivel between the wire and the sheave, but in practice I'm not convinced this will work. The strop and tackle are secured very close together at the bottom, so there isn't much providing an anti-twisting force, and I would expect a swivel to bind to some extent under the load.
I guess my options are a single 8:1 tackle (if I can find 4-sheave blocks, and if that doesn't just end up revolving and twisting as well) or some sort of mechanical adjuster (the wheel or folding-arms kind). But maybe there's something else I haven't thought of, or a cunning way of stopping the twist on the existing arrangement?
To be clear, this is a fractional rig and I do adjust the backstay tension while sailing, but not with great accuracy or urgency. It's also not vital to holding the mast up (the aft-swept cap shrouds do that) although there would be a risk of inverting the bend if the masthead was released while sailing. The backstay chainplate is on the centreline and there isn't really anywhere to attach the legs of a Y-shaped system.
Cheers,
Cheers,
