MapisM
Waddumean "or"?You don't listen or learn very well.
Never had a reason to test this P.P, just for clarity: I only suggested that as a temporary/quick/rough check of negative pressure inside the e/r, nothing else.
But while you are mentioning your 42, did you ever experience a delta T of 40°C inside her e/r at cruising speed? Or on your previous 39?
I'd expect the usual reasons of conservatism and lack of imagination. Cost may also be a factor, though LFP and other chemistries are getting cheaper by the month.Why aren’t the big builders fitting LifePO4 batteries standard?
But you don’t use your geny to full advantage and have solar .since Porto obvs knows better than ppl that are trying to help and have been using LifePO4 banks in mobos for the last 4-5yrs, I'd suggest OP should follow his suggestions and stick to stock Azi design.
Since I cannot be bothered to google and find relevant (or irrelevant) articles supporting what i've been doing for years now, I'll just keep quiet
V.
Flemming yacht electrical installations
Still haven't learned anything, have you ?But you don’t use your geny to full advantage and have solar .
So we are in agreement interms of if you have and prepared to use a functional geny . Plus if
you motor about . A lot a well .
The dichotomy here is if you have a working geny * and use it .
It seems to be lost on folks .
* defining working geny as unobtrusive to the boat users and anchoring neighbours .
It’s sound proofing and water exit noise mitigation. Also large enough to cope with what ever other systems you run as well as the obvious charger .
Really big boats have permanent genys running . A whole suite often different sizes . They don’t 9iss around with batt bank management and litter the top sides with solar .
If you can't blind them with brilliance, baffle them with bullsh1t.Still haven't learned anything, have you ?
By the way - this is one major restriction: All connectors, main circuit and the battery boxes on an AZI 46 are in the engine room. I have no other place on the boat to install a large battery pack.since I raised the temp issue, and regardless what Porto says, IF you go the LifePO4 route, DON'T put them down there in the engine room with such temps.
The life span of lead acid batteries is severely shortened if kept in a 40 deg environment.By the way - this is one major restriction: All connectors, main circuit and the battery boxes on an AZI 46 are in the engine room. I have no other place on the boat to install a large battery pack.
I expect he can afford to replace them!The life span of lead acid batteries is severely shortened if kept in a 40 deg environment.
Beware, you're mixing up numbers - unsurprisingly, in a surrealistic debate like this!The life span of lead acid batteries is severely shortened if kept in a 40 deg environment.
I understand the delta temps, but lead acid batteries start to suffer badly at 40 deg and above. Despite earlier comments, LifePO4 don't like 60 deg and above.Beware, you're mixing up numbers - unsurprisingly, in a surrealistic debate like this!
Unbelievable as it may sounds, we are talking about a 40 deg delta temp between the exterior and the e/r.
The OP said that with 30 deg outside, he has 70 deg in the e/r, no less...
Worth checking the water level of FLA batteries and top them up after each and every boat usage, methinks...!
I appreciate that 40°C isn't ideal for FLA batteries - let alone 70°, of course!lead acid batteries start to suffer badly at 40 deg and above
Exactly ^I appreciate that 40°C isn't ideal for FLA batteries - let alone 70°, of course!
But I've got to say, while personally I dislike the placement inside the e/r, that's a rather widespread solution not only in Azimuts, but also in boats built by several other builders, mine included.
And in the Med summer, where 30°+ outside temp is quite common, 40°+ inside the e/r is to be expected.
But in my experience, good FLA batteries withstand that rather well.
For instance, so far I sticked to the OEM FLA batteries arrangement in my boat - though I'm planning to at least consider LFP, upon the next replacement.
That's made of two banks in parallel of four Trojan 6V batteries each, for a total of 450Ah @24V.
They were last replaced in 2017, and being inside the e/r, they are often warmed up to 40 deg or so.
Sometimes even a bit more, in very hot days - though never above 50, which would even trigger an alarm.
And as of today, they are still doing their job just fine.
In fact, based on their usual service pattern, I'd be surprised if they wouldn't last another couple of years, hopefully a bit more.
So, if they'll make it to a decade or so of service, I think it would be unfair to complain, even if there's plenty of FLA batts much cheaper than Trojan.
BUT, I do take care of them, never discharging them very deeply, always recharging them "softly" (I've set to 30A the max bulk recharge, even if the Multiplus could supply up to 70), checking levels regularly, etc.
When I hear of boat batteries only lasting 3 or 4 years, I can't help thinking that they are at least to some extent neglected...
Since updating my power system a year ago i haven't used the genny once.With these type of med boats and typically usage pattern you learn to LOVE your geny ….. end of all this batt anxiety.
Forgot to bring in air conditioning.Since updating my power system a year ago i haven't used the genny once.
Suits me just fine.
We ran a 42K btu system.
Even while motoring to our next anchorage I would run the geny ( charger off as alternators on ) to run the AC . To chill the boat down so we could sleep.
We had a zero gas boat ….. so inevitably needed 220 v sometime during a day . 3 burner hob
I suspect these would kill via an inverter only …. Very shortly a battery system. Even yours expensively:
The geny gobbled 2 -3 L/hr of diesel.
The main engine s 180 to 200 out of 2000 L tank age .
Running the silent geny was a no brainer . The ops AZ 46 I suspect will copy this usage pattern .
It’s well trodden path in the Med once Mobos get over a certain size .
That’s the dichotomy I was referring to .
