Skipper Felice
Yes - it goes into this direction ...Forgot to bring in air conditioning.
We ran a 42K btu system.
Even while motoring to our next anchorage I would run the geny ( charger off as alternators on ) to run the AC . To chill the boat down so we could sleep.
We had a zero gas boat ….. so inevitably needed 220 v sometime during a day . 3 burner hob
I suspect these would kill via an inverter only …. Very shortly a battery system. Even yours expensively:
The geny gobbled 2 -3 L/hr of diesel.
The main engine s 180 to 200 out of 2000 L tank age .
Running the silent geny was a no brainer . The ops AZ 46 I suspect will copy this usage pattern .
It’s well trodden path in the Med once Mobos get over a certain size .
That’s the dichotomy I was referring to .
I think our generator is very valuable - at the moment he has only around 600 hrs.
The previous owners (1. + 2. owner) have fitted three air conditioning units (.....) (Cruiseair). They run very well and are controlled independently. All running is about 15A @ 220V AC. (appx. 3.5 kWh) in the marina this is no problem - shore power ... the ONLY possibillity to run this offshore is with the running generator ....
As I am not a big friend of permanent airco - but as of theese days with 35deg outside and enjoing the boat in the marina it is a pleasure and some luxury to have 25deg inside!
