dancrane
Daft project I know, and I don't care. If it doesn't make sense or it's too much work, I'll drop it by midsummer. Possibly much sooner.
I could just go ahead and do it and present photos of the finished job, but I know little about working with ply so I'll benefit from comments along the way.
I have an old Avon Redcrest and an old Redstart. The project is to give one of them a removable plywood RIB-style hull to make the most of my Tohatsu 3.5.
It's tempting to use the smaller 8ft Redstart which I think holds pressure better. Plus, the Redstart is missing the loops for the standard outboard bracket so cannot otherwise take an engine, and being smaller, may go faster with a hard hull beneath.
Three years back I thought how to attach the outboard to my Osprey dinghy without damaging or altering the stern, which wasn't built to carry an engine. I created a solution using 1.5mm stainless sheet (with butyl rubber padding) to spread the engine's weight and thrust rather than damaging the only available contact area, above the transom.
If there was a clever bit, it was using 90° stainless exhaust sections to turn the pipes supporting the weight, into verticals that hold the wood bracket.
I admit, I don't know how clever that was because I don't know if 1.5mm-thick 304 exhaust pipe is strong enough for that job. Your views are welcome.
I had to scrap the Osprey before trying the o/b on it, but I want to repurpose the pipe elbows & bracket to connect the engine to the ply hull for the Avon. I think any other connection would involve lots of solid wood. Below is the bracket, now upturned because the pipes will be inside the flat top of the rigid hull.
I'm thinking I'll drill out the rivets holding that sheet metalwork to the exhaust elbows, and rivet on a new stainless sheet to sheath the ply it will connect to.
What I don't know is the exact shape the ply hull should take. I guess it needs a flat top (rising forward, so the hard floor includes the raised bow of the the rubber dinghy). That central 'deck' can include a robust portion under which the engine bracket pipework can be bolted.
Then (I'm speculating) I could screw or glue pre-shaped, pre-cut 20mm softwood planks to the underside of the plywood 'top', along their long edges, so their bottom edges provide the underwater curves of the hull...and a skin of Robbins 5mm Super Elite (or something cheaper) can form the outer skin.
But what shape should that outer be? Somebody recently said on the forum that flatter is better for speed, but shouldn't I incorporate some V? How much V? Is it okay with a pronounced V forward, becoming flatter aft?
And should the hard hull be squared-off at the point where the engine attaches, or should it reflect the round-tail shape of the dinghy?![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Actually I'm going out to the shed after I post this, and by the time I come back I may have decided to forget it...unless anyone thinks I should go ahead?
![52139335880_796a2f5e1a_c.jpg](/proxy.php?image=https%3A%2F%2Flive.staticflickr.com%2F65535%2F52139335880_796a2f5e1a_c.jpg&hash=c624ce47df887aa006151877b975ee5b)
![53752833267_eb0866d056_z.jpg](/proxy.php?image=https%3A%2F%2Flive.staticflickr.com%2F65535%2F53752833267_eb0866d056_z.jpg&hash=634bbc6b79aa65dbb4d482525b0042ef)
![53752857387_df28dab099_z.jpg](/proxy.php?image=https%3A%2F%2Flive.staticflickr.com%2F65535%2F53752857387_df28dab099_z.jpg&hash=b0c12013ba1cf6395b51b83fddf7ab7d)
